If I end up going with Kitronix they do laser ply too. They have poplar as well as birch which apparently cuts better. I have some but I haven’t tried it yet. Too many projects, not enough time…
Most places don’t sell 1mm because it is so fragile. 2-3mm is the minimum that you’d want to use… You can get it but you’ll end up buying a 2.5x3 meter sheet from the manufacturer…
I would buy some Acrylic but I don’t have money right now…Would be nice if the space could buy a few sheets as replacement for all the test pieces I have had to do for getting it up running.
Ok fine, 2 of 300x300
I say this as I’m not sure how you cut it.
I’m also not sure on costs so want to be minimal for first play
Can you detail the “too small” issue?
The thing that attracts me about the offcuts bin at Hamar is that (apparently) pieces are £1 each, 3mm is normally around A3 size and there’s a variety of stuff there. As I’m not sure what projects I’m going to be doing with it I think a variety would be good!
