Any ideas what’s going wrong here? I’m using the same settings as I normally do, but a different make of filament. Looks maybe like not enough filament being extruded?
3D print fail
Are you printing with the auto settings on Cura for your specific material? Because that looks like maybe the print temp. is too low for the filament…
No, but I’m using the same temperature that works with the other brand of PLA I use that works fine.
I’ll try upping it to 210? 200 at the moment.
Hard to says despite the old saying that picture is worth a 1000 words it will help to know the settings, material and printer
From the pic it seems the layer height is pretty big are you over 0.4 . We can also see some delamination this might back caused by to low temp as you’ve guessed but depending on filament quality it might require to be dried
