He says on the notes that the bearing are shot!
here’s his site: http://www.rc8wd.com/?page_id=80&lang=en
Though the original French version might suit you
Ok he completely swapped the lead screw + nut block assembly and added new bearings to get rid of backlash, that’s quite a big mod
Also put in a new gearbox for some reason. I think it might be because the speed control is unreliable on these machines, I found it would not operate properly from time to time.
i think the benefit of the belt drive is so you can use the machine both in manual mode and cnc .
with direct drive manual is impossible
Wall mounted with suction table?
We’re getting a Shape Origin, aren’t we? Aren’t we?
As soon as they’re available in this country, if I’ve got anything to do with it.
MMMMMMM look what I have found!
http://www.pocketnc.com/pocketnc/pocket-nc
video of it in operation on kickstarter
https://www.kickstarter.com/projects/1090944145/pocket-nc-the-first-5-axis-cnc-mill-for-your-deskt
the best part of this is it is a kickstarter project that actually delivered, and the reviews are good.
$4000 dollars id a push i know!! but i can only dream.
its got to be worth it just to make that v8 engine they make on the demo!
how about these
Now that is quite a beautiful looking thing.
I’d want to see it in action though - as well as get a good idea as to how asshatted the tool chain is.
This company is london based, maybe we could get them to come down and do a demo?
You can, better still ask David Penny he is a member and has contact.
Maybe we could offer to demonstrate it so their south London, Kent, Sussex and Surrey potential customers can come and see it working
I can’t see that long z axis column cutting through any hard materials without having a problem
at $5000 for 5-axis you’re probably going to get something really very basic
for the same price range tormachs PCNCs look much, much beefier
Links please
Making a 4 by 8 would be nice
CNC mill, not router. The former we have space for. The latter we don’t, I’m afraid.
CNC mill mine is in progress using ballscrews its about a4 i had some result wit a programe
caled KCAM its entry level parelell port i plan to try it with MACH 4 its in a suitcase just now i can
bring it electronics night
